Im planning to buy this one plus Digirig lite (2+2 pcs) Albrecht AE5900 Mini SSB 40kan Am/Fm/Ssb and use with Digirig Lite if I can get the right cable from here.
Is there any cable that have the right configuration for the connection?
Also, can you see in the manual if it’s even possible to use this model together with Digirig and Vara FM?
I have concept with my 2 Anytone 878 and Vara FM, now I want to experiment with 27 MHz and this Albrecht.
At this time there is no cable in store for the Albrecht AE 5900 Mini SSB, but the manual has the microphone pinout (11.2, page 47), so it should be possible to use the radio with Digirig and VARA FM. I haven’t tested it. The cable takes PTT and transmit audio from the RJ45 mic socket and receive audio from the 3.5mm SPEAKER jack on the back:
RJ45 pin 1 (GND) → 3.5mm TRRS sleeve (GND)
RJ45 pin 4 (MICG) → RJ45 pin 1 (GND)
RJ45 pin 3 (MIC) → 3.5mm TRRS ring 1 (RIG_AFIN)
RJ45 pin 8 (PTT/RXD) → 3.5mm TRRS ring 2 (RIG_PTT)
SPEAKER 3.5mm tip → 3.5mm TRRS tip (RIG_AFOUT)
SPEAKER 3.5mm sleeve → not connected (ground comes through RJ45 pin 1; this also keeps it safe if the speaker output turns out to be bridged)
The closest store cable is the AnyTone AT-778UV Audio/PTT cable: AnyTone AT-778UV Audio/PTT Cable – digirig
It has the same GND, MIC and MIC GND pins and the speaker tail, but PTT is on RJ45 pin 2 instead of pin 8. It won’t key the AE 5900 as is; the PTT wire has to be moved from pin 2 to pin 8 on the RJ45 plug. If you have a crimper, it’s a matter of re-crimping the RJ-45 jack.
On the radio side, select FM mode, keep Microphone type at TYPE1 (7.4.1), and turn off VOX, RX/TX NRC, HI-CUT, ECHO and Roger Beep, since they alter the audio.
Please report here if you decide to give this build a try.
Thanks for the very detailed explanation and instruction, with this I don’t doubt I can reorder the pins, maybe also with little help from Youtube-videos.
I will also order 2 more Digirigs. Looking forward to experiment with 27 MHz, Digirig and Vara.
I guess Vara FM work for this, if not I try Vara HF.
