Alinco DR-735T + DigiRig Mobile audio issue
I am having an issue with the following setup and audio not getting from the radio to two different PCs . Any help would be greatly appreciated.
Radio: AlinconRR-735T
Interface: DigiRig Mobile with 6-pin Yaesu FT8xx cable.
Software: Winlink Express and Vara FM.
Radio transmits, is heard by the local Vara FM gateway on 2m. The station responds but the received audio is not being heard by both PC’s I have tried. I’m including pictures of the audio settings.
I’m very familiar with Digirigs and have never had an issue like this that I haven’t been able to solve.
does the DR-735 require a menu setting to use the packet jack?
(data mode/PKT/aux etc)
i see that you can key the TX but perhaps the audio is only present on the jack with a particular combination of radio settings.
correct A or B band.
correct baud rate selected for the packet jack
(just to select the correct pin, not an actual speed limitation)
usually the 6pin pkt jack is the easiest way to get connected, crazy.
Yes, all settings on the radio are correct. I can unplug cable from the Digirig Mobile, plug it into the Digirig Lite, and everything works as expected.
@K0TX might have an idea i missed.
sounds like you’ve got radio + pc dialed in.
you can plug in headphones to check audio out of the digirig but i’m not sure how to check audio IN to the digirig. (other than the PC hearing it :slight_smile: which it doesn’t so far)
it may be a physical failure on the digirig audio + ptt connection itself.
sorry i couldn’t be more help
The two interfaces (Mobile/Lite) create separate instances for the audio devices. When swapping hardware, make sure to also swap the audio device references in the software configuration. Even before that, check the levels bar next to the recording device entry in the control panel.
With the same levels set if one interface shows activity and another doesn’t then the hardware may be at fault. If that’s the case, please submit a service request through the contact form on the website.
I double checked all of the settings and did some more testing. Issue is now occurring with a known working radio with my original DigiRig. I’ve submitted a message through the website Contact Form with more details.
