Anysecu A6. Necesidad de relé en kgStv
Mi walkie Anysecu A6, solo Ptt unos segundos, en kgStv, necesidad de un Relé. Como configuro está tarjeta para usar también como rele?
The possible reason for PTT not holding is RFI disruption Digirig’s functions. If you have a dummy load, you can try transmitting with it to see if the PTT problem continues or not. If there is no problem while using a dummy load, then you’ll need to improve the counterpoise in your radio’s antenna and increase chocking of Digirig cables.
