Cable to use with the db15port on a Kenwood TK7360
Hi all. I’m looking at making a cable for my digirig to use for my Kenwood TK 7360. I could go the route of using the RJ45 mic port but the db15 connector has me curious to try that. I’m familiar that pin4 and 5 are audio in and out and a few of the ports can be programmed with the CPS. At which case one port will be for use as external ptt for data. Don’t have the components yet to make the cable up but I was just curious for y’all that have owned this radio if y’all have had luck with using the db15 port in the back and if there might be some things I need to consider that I may not have thought of. Thanks.
