# Cables for ICOM M-803 (marine SSB and HAM transciver)
**URL:** <https://forum.digirig.net/t/cables-for-icom-m-803-marine-ssb-and-ham-transciver/1238>\
**Category:** Uncategorized\
**Tags:** icom-m-803\
**Created:** [March 6, 2023, 7:38pm UTC](https://forum.digirig.net/t/cables-for-icom-m-803-marine-ssb-and-ham-transciver/1238 "2023-03-06T19:38:22Z")\
**Posts on this page:** 1\
**Showing post:** 1
<div class="post-metadata">
**Author:** ![markD](https://forum.digirig.net/user_avatar/forum.digirig.net/markd/32/992_2.png) [@markD](https://forum.digirig.net/u/markD)\
**Post date:** [March 6, 2023, 7:38pm UTC](https://forum.digirig.net/t/cables-for-icom-m-803-marine-ssb-and-ham-transciver/1238/1 "2023-03-06T19:38:22Z")
</div>
Hi,
I have a brand new ICOM M-803 a dual role transciver (MARINE SSB and HAM). This unit has been designed to use any of a PACOR modems. I have no itentions to follow this road. I want to use WINLINK, PAT, VARA together with my LINUX box.
M-803 has a dedicated 9 pin serial port to connect with a computer. Its pins are as follow:
1 DCD Inputs terminal for carrier detection.
2 RXD Inputs terminal for receive data.
NMEA-OUT NMEA0183 ver 4.10 data output.
3TXD Outputs transmit data.
NMEA-IN NMEA0183 ver 4.10 data input.
4 DTR Outputs data terminal ready signal.
5 GND Connected to ground.
6 DSR Inputs terminal for a data-set-ready signal.
7 RTS Outputs request-to-send data.
8 CTS Inputs terminal for clear-to-send data.
9 NC No connection.
**Its serial port for modem connection (PACTOR):**
1 MOD+
Modulation input from an external
terminal unit.
Input impedance: More than 600 Ω
Input level: Approximately
0.77 V rms
2 MOD– Coaxial ground for MOD+. –
3 GND Ground for digital equipment. –
4 AF+
AF detector output for an external
terminal unit.
Output impedance: Less than 600 Ω
Output level: More than
770 mV rms
5 AF– Coaxial ground for AF+. –
6 GND Ground for digital equipment. –
7 NC No connection. –
8 SEND
Ground this pin to transmit. Ground level: –0.5 to 0.8 V
Input current: Less than 20 mA
9 GND Ground for digital equipment. –
REMOTE Pin Pin name Description
**Finally, its ACC (round) ports pinout:**
ACC Pin Pin name Description Specification
1 CWK CW and FSK keying input. Input level: –0.5 to 0.8 V
2 AF GND Ground line for AF signal. –
3 SEND
Input/Output pin.
4 MOD
Modulator input.
Usable when pin 3 is grounded.
Input impedance: More than 10 kΩ
100mV rms
5 AF
AF detector output.
Fixed, regardless of [VOL] position.
Output impedance: Less than 4.7 kΩ
Output level: 100–300 mV rms
6 NC No connection. –
7 13.6 V 13.6 V output when power is ON. Output current: Maximum 1 A
8 ALC
ALC voltage input. Control voltage: –3 to 0 V
Is it possible to create a set of cables to control this radio?
with the best regards,
Mark
_[View the full topic](https://forum.digirig.net/t/cables-for-icom-m-803-marine-ssb-and-ham-transciver/1238)._
