Hi folks:
I recently purchased a Digirig Lite and the Baofeng HT Digirig Cables Set, which I’m trying to use with my Explorer QRZ-1 to do AX.25 (Packet 1200) on UHF/VHF. This is my first time using digital modes.
I observe that the PTT LED on the DigiRig lite is lit up red when my laptop, DigiRig, cable, and HT are all plugged in together. If any of these are unplugged, the PTT LED goes dark – however the HT does not have to be on for this to happen. Additionally, this occurs when plugging the DigiRig into an Android phone not producing any audio that does not have any software modem software installed. (The DigiRig power light stays lit green the whole time.)
When the HT is turned on and the squelch is set to 0, I observe the transmit/receive LED on the HT toggles between green (receive) and red (transmit) even when no software is interfacing with the DigiRig. This generates undesired transmissions and interferes with the ability to receive signals.
Using the green programming cable instead of the black programming cable results in the PTT staying dark, but obviously also prevents use of the DigiRig to transmit or receive. This interferes with my ability to use AX.25.
This seems similar to the issue reported at Digirig lite immediately engages PTT when plugged in – it is not clear whether that was confirmed to be a hardware defect or some other sort of problem.
Any idea why simply plugging in the different components would result in PTT going and staying active, even in the absence of any sound modem software running?
Thank you,
KO6ONV
