# ICOM IC-229H Support
**URL:** <https://forum.digirig.net/t/icom-ic-229h-support/4470>\
**Category:** Uncategorized\
**Tags:** icom-ic-229h\
**Created:** [September 19, 2024, 11:56am UTC](https://forum.digirig.net/t/icom-ic-229h-support/4470 "2024-09-19T11:56:33Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![Constrainted](https://forum.digirig.net/user_avatar/forum.digirig.net/constrainted/32/2219_2.png) [@Constrainted](https://forum.digirig.net/u/Constrainted)\
**Post date:** [September 19, 2024, 3:18pm UTC](https://forum.digirig.net/t/icom-ic-229h-support/4470/2 "2024-09-19T15:18:15Z")
</div>
I do not have your radio, but I don’t want your question to go too long without a response.
For the ICOM IC-229H see:
> [@Cable for ICOM IC-229](https://forum.digirig.net/t/cable-for-icom-ic-229/1321):
> Like often the case with the mobile radios we’re getting the necessary signals from two separate connectors: Digirig’s audio cable should look like this: MIC pin 1 (MIC) → 3.5mm TRRS ring1 (RIG\_AFIN) MIC pin 5 (PTT) → 3.5mm TRRS ring2 (PTT) MIC pin 6 (GND) → MIC pin 7 (GND) → 3.5mm TRRS sleeve (GND) 3.5mm TRS tip → 3.5mm TRRS tip (RIG\_AFOUT) 3.5mm TRS sleeve → 3.5mm TRRS sleeve (GND) Manual [here](http://www.radiomanual.info/schemi/ICOM_VU/IC-229A_E_H_user.pdf).
> [@DigiRig Lite cable for Icom IC-229 Mobile](https://forum.digirig.net/t/digirig-lite-cable-for-icom-ic-229-mobile/4351):
> Dusted off my Icom 229H to use with Winlink. Using a TRRS B-O-B and an Arduino jumper set, here is what the cabling should look like. [https://groups.io/g/VARA-MODEM/topic/digirig\_lite\_to\_icom\_229h/108265905](https://groups.io/g/VARA-MODEM/topic/digirig_lite_to_icom_229h/108265905)
Good luck.
_[View the full topic](https://forum.digirig.net/t/icom-ic-229h-support/4470)._
