# Kenwood TS-140s compatibility (with 6 & 13 pin connector)
**URL:** <https://forum.digirig.net/t/kenwood-ts-140s-compatibility-with-6-13-pin-connector/376>\
**Category:** Uncategorized\
**Tags:** kenwood-ts-140s\
**Created:** [October 14, 2022, 1:19pm UTC](https://forum.digirig.net/t/kenwood-ts-140s-compatibility-with-6-13-pin-connector/376 "2022-10-14T13:19:59Z")\
**Posts on this page:** 1\
**Showing post:** 9
<div class="post-metadata">
**Author:** ![K0TX](https://forum.digirig.net/user_avatar/forum.digirig.net/k0tx/32/3_2.png) [@K0TX](https://forum.digirig.net/u/K0TX)\
**Post date:** [December 5, 2023, 3:49pm UTC](https://forum.digirig.net/t/kenwood-ts-140s-compatibility-with-6-13-pin-connector/376/9 "2023-12-05T15:49:32Z")
</div>
Voltage levels: See [the answer to your question re IF10-C](https://forum.digirig.net/t/kenwood-ts-140s-and-cat-control/2193/6) in another thread.
TXD/RXD lines will be used for data and are required. Sometimes CTS/RTS lines are also expected and Digirig doesn’t offer external connections for those. However in most cases the CTS-\>RTS loopback connection AKA hardware flow control bypass works around this requirement.
_[View the full topic](https://forum.digirig.net/t/kenwood-ts-140s-compatibility-with-6-13-pin-connector/376)._
