Hi,
I have the Digirig Mobile RS232 version, a Yaesu FTM MiniDin10 Cable (SKU: YSU10CAT): https://digirig.net/product/yaesu-ftm-cable/e, and an FTM150E. I only see one COM3 port, and it works with RST for PTT activation. With Digirig and Soundmodem, everything works perfectly. For programming the radio via the ADMS-17 software, do I use the same COM3, or should I see another one? In the menu, I only find COM3, which is obviously occupied by Soundmodem and RTS. I tried using COM3 in ADMS-17, but when I try to communicate with the radio, I get an I/O error. Should I see another COM port, or is it normal to see only COM3? Should it work?
Can you help me?
Gianluca
Translated with DeepL.com (free version)
