PTT not working for Yaesu FT-65 or FT-4X - not a DigiRig problem or DigiRig cable problem
Steve,
I found below info here:
Audio IO
Motorola M1 connector
  • 3.5mm :
    • Tip = speaker- (Vcm = 2.5V)
      • Jumps to 2V when squelch is open. Audio max = 4V (with respect to GND)
    • Ring = ?
      • internal 10K PU to 3V3, unknown purpose
      • Short circuited to sleeve when using the SSM-17B Hand speaker Mic. Maybe that’s the reason why Yaesu doesn’t market the SSM-17B as an accessory to the FT-65. The SSM-512B is advised instead.
    • Sleeve = speaker+ (Vcm = 2.5V)
  • 2.5mm :
    • Tip = Connect a PTT switch in series with electret-MIC (1K8 or 2K2 internal resistance) connected to GND. Function generator outputs must be AC-coupled to this input, otherwise the PTT functionality no longer works correctly.
    • Ring = RX/TX line
      • RX/TX Short circuited to sleeve when using the SSM-17B Hand speaker Mic.
      • Use open drain TX and connect it to RX.
      • To interface to a standard UART: connect the anode of a diode to the UART-RX. Connect the cathode of that same diode to the UART-TX.
    • Sleeve = GND
This confirms that we are absolutely safe using TS (2 pin) connectors on both sides.
Now the issue you are reporting is likely to do with the mechanical fit. I did overlay of parts of the photo you shared and it confirms what you observed: that the tip part is of different length on 2.5mm side between Digirig cable and speaker/mic.
There is a good number of these cables out in the wild, but this is the first time that I remember this issue coming up. I’ll keep it in mind when reordering this model.
Thanks! I appreciate it and I would be happy to test any revised cables.
But as far as the SSM-17B goes, that’s exactly what Yaesu lists on their accessories page for the FT65R:
I think I found a matching connector. Will prototype with the next order and reach out for testers.
Wonderful. Please let me know how I can help.
Hello! I am so happy to have found this thread, I had to make an account to reply right away.
I have the exact same problem with my FT-4X but kept thinking that I was doing something wrong until I was able to build a cable for my AnyTone at-778uv and confirm that it works as expected.
The cable I’m using is the coiled digirig cable that looks exactly like the one smshannon55 posted pictures of. Any chance I can get in on the replacement/testing bandwagon?
Gabe,
Welcome to the forum!!
I’m sorry for your frustration, but relieved (selfishly) that I’m not the only one to have this issue. I’m not the person who can help, but I wish you well!
I’ll make an announcement in the thread when the replacement is available. Please stay tuned.
Denis got a prototype cable to me and it works.
Awesome, I’m excited to hear that it’s looking good so far.
Hello, have there been any more updates on this?
The cable Denis sent works. I suspect that’s what he is stocking now. Maybe he simply forgot to announce it.
I have a test run of the updated cable. Please reach out to me via PM after Monday and I’ll be able to shoot a replacement.
Glad I found this thread! I am in the same boat. Is this something that can be specially requested for purchase?
There is no need to specifically request. The current inventory has been updated since.
