Installed the Radioddity DB25 25W quad-receive, 2m/440 radio (roughly $100 on Amazon). Great little radio in my ARES gobox. Really great application for this little radio. This problem isn’t really unique to the DB25, but what I’m using now.
Because it’s the only 2M/440 radio in the box, I need it to be able to work for both voice and data. Works REALLY great with the audio-only side of a DigiRig-Mobile (use both cat and audio with FT857D also in the box, but the VHF/UHF finals are blown in that radio).
Like I said, it works great, however, I have to keep the audio levels at 5 for VARA and AX.25 (and thank you K0TX for the Claude magic…about at the end of the postpone maintenance window so you’lll hear from me shortly on that) in Windoze 11 and the volume control on the radio just barely above nothing.
As with many rigs with a speaker out or similar to this with a dedicated port, the radio speaker is muted when the AF/PTT plug is inserted. This makes it unusable for voice traffic. In order to work voice, you have to reach around to the back and pull out the plug, and then raise the speaker audio level, and then on reverse, basically, you have to plug it back in and reset the audio levels. Quite a bit of pain operationally.
I made a switch box that takes care of the pulling out the plug problem, but the audio levels still have me scratching my head.
One thing I’ve considered is removing the JP3 ATT jumper. I’ve always had to keep the audio levels pretty low for the 857, (around 12-15), so maybe that’s the answer. Are there any other adverse effects from running everything at 20dB down in the DR Mob?
There is not a lot of risk in giving that a try to see if the attenuator helps.
Since you already adding the external box for switching, you can also stick a couple of potentiometers in it for the level adjustments Signalink-style. You can use one in each direction. 10K’s will work.
Denis - -Thanks. I guess I wasn’t clear about what I was asking or about the switch box. I had made the switch box and discovered that the audio level was essentially inaudible when I switched over to VHF. So…I ended up having to adjust the volume control, which then necessitated re adjusting the Windoze sound level switching back. For digital w/ the DR, I have the volume control on the radio set to just barely over where the speaker in the radio completely cuts out, and even then, I have the W11 audio in set to 4 or 5 on the slider.
So my question really comes from not knowing squat about what those numbers are on the slider in W11, or more specifically, approximately what putting the 100K resistor inline by cutting the JP3 jumper changes the slider value to. I know what 20dB is, just not what it does to W11. In theory, 20dB should be about 3 S-units down, and if full scale is S-9 (the mythical full scale), then the AF out should be around S-6, or roughly 2/3 scale, so would Windoze setting be about 66?
I’m probably comparing apples to oranges, but translating from dB to some number in Windoze is a challenge. Maybe trial and error is the only answer?
Anyway, noodling some more, I also realize that I don’t want to have to change settings when moving from HF radio to VHF. I only want to use 1 DR because of limit on #of USB ports on the computer and desire to minimize device count in the box. So I came up with this circuit.
My thinking here is to keep the volume setting on the VHF radio HIGH and then use a 100K pot to bring it down to some reasonable value. Same with the HF, except I think on the 857 that the volume control does not change the AF OUT in the 6-pin mini-DIN dataout/audio. So not sure if that should be 100K or 10K.
Does this make sense? Am I over complicating things? Does anyone simply combine to AF signals together using a TRRS plug to dual TRRS jack cable such as this:
The Windows slider isn’t dB-linear, so mapping 20 dB to “66” won’t hold — treat the slider as arbitrary and calibrate by ear or with a meter. If the goal is one DR across both radios without touching Windows between them, putting a 100K pot on the VHF side to trim its hotter output makes more sense than fighting the slider. Your note about the voice/speaker switch is the key one; get that routing right before worrying about level numbers, since the DR’s input range is what really sets your usable window.
That’s exactly what I did. 10K pot to a speaker/headphones, 100K pot to the RIG_AFOUT on the DR.
Funny thing. I set the radio volume to just below distortion with the 10K pot wide open and 100K pot to roughly halfway and it was within 3dB of the original level for VARA FM, so I got an APPROVED in AutoTune first try. HF worked just fine as well.
Yes, it is has the added benefit of working around the Windows audio clumsiness in addition to my problem with the radio cutting out when using the rear speaker or “data” jack. It’s not without some cost. The obvious is more hardware…a minimum of two pots, one for the speaker audio and one for the AF IN, as well as cabling and jacks, and possibly switches.
You have to wire this all up (I can share a schematic), which means you cannot use the very well made cables from DigiRig. You must take care not to introduce noise, through either construction or through noisy parts
I have an extensive parts supply, so I didn’t buy anything new except for two TRRS cables off Amazon (8 bucks). But the total of all parts new including case, pots, phone jack, a small speaker) is a good more than just a cable from DR.
As Denis pointed out, this is basically the SignaLink approach…and sorta defeats the real genius of the DR solution.
My workaround is still subject to “whacking” by M$ software updates, as that problem was related to M$ changing registry entries during update not it changing my levels (VARA FM/HF & SoundModem weren’t affected, but Graywolf is).
This is my ARES GoBox. DigiRig Mobile is on lower shelf next to power supply and the new box on the shelf above it, below the Radioddity. FT857 Is to the right of the Radioddity. Remote head is detached as the office supply case won’t close with it attached. In this photo, the HF cables are in the DR…as the Ft857 supports CAT, although CAT is wired through Mic jack as there is an FC-30 tuner that uses the CAT port.
