I’ve used HRD for years with Yeasu 991A. I recently downsized and decided it was time to pass that radio on to someone who would make more use of it than i was. So I am in the process of learning the ins and outs of my G90. I set up the Digirig and HRD provided guidance how to connect it up using the Xeigu interfaces but decided to give the Digirig a shot and to my surprice using the ICOM 7000 settings as they suggested it came right up. I can change cefrtain functions tune etc. So I figured the next move was to try and make use of WSJT. There is where I’ve run into a problem I can work out. WSJT says the CAT function is working but when I set a frequency in WSJT it doesn’t move. During the setup I could see it was handling PTT just fine.
Has anyone successfully used HRD with this combination?
As always thanks in advance.
