Which cabel is for the Alinco DR 735? It has the 6 pin mini-DIN port. I have a Digirig Mobile for the IC 706 Mk 2 G. It has two ports on the unit. Can I use it for the Alinco?
This transceiver uses a Mini Din 6 socket with the standard Yaesu pinout:
Cables:
- 1200 baud: Yaesu FT-8xx cords (Mini Din 6 cable)
- 9600 baud: Yaesu and Icom 9600 baud MiniDin6 audio cable
Full information see page 72 of the user manual.
ok. Was there a resolution on this?
I am thinking of purchasing an Alinco 735T.
I already have a digirig unit (Logic Levels), and the Yaesu 8xx cables.
Is there a definite YES on this?
Jerry WF5W
If you don’t hear from the original poster then just go ahead and give it a try.
It is highly likely to work and if it doesn’t you can return the cables.
