Anytone 5888UV Not Working
I have an Anytone 5888UV, and just purchased the AT778UV cable which has been said to match the pinouts. I know my new Digirig works as I’ve successfully used it with three different PC’s and three dufferent HT’s to use VARA FM to a local RMS on 5 watts. When trying the 5888UV, it attempts to connect but is not successful. Tried a gain antenna and higher RF output, but no joy. Anybody successfully use the Digirig with the AT 5888UV? Thanks in advance.
As far as the cable itself is involved, all it needs to do is insure the audio from the transceiver reaches the computer, transceiver is keyed up and audio from computer reaches the radio. You can diagnose each of these functions separately as demonstrated in the troubleshooting videos at: https://www.youtube.com/@digirig
If all of the above working as expected then the issue has to do with the transceiver settings, audio levels or RF performance.
