AT-6666 Pro DigiRig
Any chance this fine company will create a digirig cable for the AT-6666 Pro in the near future ?
Do you have the pinout of the cable?
Denis K0TX published the pinout:
Please take a look at the thread to answer your question.
Thank you for your interest in AT-6666 Pro. At this time there is not enough demand for this cable to justify a production run. I’ll keep monitoring the feedback to see if this changes. For now, please consider a homebrew option.
Now that we have the pinout, I wonder if there is anyone on the forum that can make a “best guess” complete wiring diagram from radio to pc that includes the correct digirig to make this work on an AT-6666 Pro. If I can get that, I’ll buy the hardware and give it a shot and post results back on the forum.
The connections in the cable are described in the same linked post.
This cable will work with Digirig Mobile in any configuration or with Digirig Lite.
Denis K0TX, Thank you so very much for the reply…
Since I already have one digirig mobile, I can get started and order some 3.5 mm TRRS plugs with cables and some GX16-6 mic connectors to work with… being an old newbie ham, it will take a bit of time and I will probably have lots of questions along the way, especially with what software to use with the AT6666 pro. What I am wanting to do in the end is use the 6666 for CW stuff . Thanks to everyone
Sounds like a plan. As far as CW goes, there may be nuances - you can certainly send it as a tone over the audio channel, but in its classic application the CW is an empty carrier being turned on and off. To achieve that you’ll need a radio with CW key socket or a mod similar to one done in Quansheng HTs:
Denis K0TX, I probably should not have used the term CW in my reply to you. What I am interested in doing with the AT-6666 Pro is using software like Fldigi with modes like RTTY, PSK, Olivia etc. I can use those modes with my AT-578UV and the digirig and want to do the same with the AT-6666 Pro. Being a new Ham, I seem to get some of the terms all screwed up and my age is not helping either… o well… This is turning into a really nifty hobby. Appreciate you comments very much !
the 6666 does CW, it’s a multi mode 10m radio, at least that’s what the advertising says
i don’t see a key jack though so it might be the ptt button on the mic
:frowning:
