Audio input not working above -1db setting
I got my Digirig 1.9 delivered a few days ago and i have noticed that audio input works only as long as it’s set to below -1db (or 36 percent) gain. Once i set it above that i get no audio input at all.
I tested with different computers, operating systems, usb cables, audio cables (including digirig ones), transceivers and i verified with the “listen” option all well as by recording.
Has anyone had the same issue?
No dropout above 36% (or any level) in my case on Win 11, Digirig 1.9, input from Yaesu FTM-6000R.
Have you ruled out Auto Gain Control?
If I enable AGC then I get no input, no matter the level I set.
What operating system? AGC should be turned off in Windows audio settings, or in Alsamixer on Linux.
I have tried Windows 10 and three different Linuxes (a laptop, a desktop and two raspberries). Without AGC i get input if i set input level to below -1db (36 on windows, 19 on alsamixer). With AGC i get nothing, no matter the level.
It’s very difficult to help figure this out remotely without more info. Have you troubleshooted the AGC on your transceiver too? I usually shut it off, or set it to fast.
On my windows machine connected to my FT897, I currently have playback set to -3.5dB and recording set to zero dB. Additional settings adjustments are needed on my transceiver and in the communications software for appropriate input/output audio levels.
I contacted K0TX about the issue and he sent me a new unit.
It has now arrived and works perfectly so the problem was in the hardware and is now solved.
Thank you for your support.
73 SV1SJG
Thanks for letting us know. Have fun with the new Digirig!
