HI al, I’ve been using the digirig with a baofeng for a while without issue. Recently it would intermittently quit txing and now it has completely quit. After trying everything I could think of I tried holding in the audio cable plug while tuning and it started to tx. I tried a different radio with the same results. As long as I hold in the plug it seems to work,
Any thoughts or suggestions would be greatly appreciated.
Thanks, Craig
Thanks Constrainted, I’ll have my multimeter back this weekend and try that. I did do the checks on the plugs/cable as suggested on the digirig youtube channel, I did have to put pressure on the radio plug but otherwise all checked ok.
I don’t know if this helps but I was able to run hf on my G-90 earlier with no issues. would that indicate the digirig is OK.
Thanks, Craig
I suspect a bad jack in the radio.
