I am about to buy a Digirig to be used for my G90 and FT891. If I buy the Digirig DR-891, can it be use for the G90 too or do I have to buy the Digirig Mobile too? What kind of cables do I need to supply with the order?
Dag,
DR-891 comes with the transceiver side cables so you’ll only need to add a USB cable. You’ll be able to use the same interface for basic operation of your G90 (audio + PTT) after adding a G90 cable set.
For optional serial CAT control of G90 you can either use the stock blue serial dongle or for a cleaner solution get a separate Digirig Mobile in logic levels configuration.
