Cable for Alinco DJ-VX50
At a quick glance Alinco’s connector looks like K1 type used in Kenwood, Baofeng and many other HTs. Upon further inspection, there is a slight difference in spacing between the pins, enough for baofeng cables not to engage correctly.
At the time of posting, there are no pre-made cables for Alinco available in digirig store. As in other cases like this I recommend a homebrew cable build using an inexpensive speaker/mic as the donor for the connector and cable. The project then consists of just adding a 3.5mm TRRS connector for the digirig’s side of the cord.
Digirig side pinouts are in the schematic here.
I just wanted to reply to this thread because it’s a little out of date, and still shows up in search results. I hope this new info may help others.
The cable for Icom HTs works perfectly with my Alinco DJ-VX50, with the other end plugged into the Audio port of a DigiRig Mobile.
