I have a UV-25x4 radio and when I connect the TRRS audio cable from the headset to the audio in on the Digirig. The radio starts transmitting. The Digirig is connected to the computer and the port is set up. I have also used this same Digirig on the UV-5R radio and it works fine. Any suggestions to get this working would be appreciated. I did also jumper from the GND to the PTT on the TRRS cable when it was connected to the radio and it did start to transmit like it should.
Thanks for any help you can give.
I did some for testing and found the UV-25x4 radio transmits when I also jumper from the GND to the PTT. It will also transmit when I jumper from SP to GND. I think this indicates I have an internal problem with my radio.
Thanks for update. If you come across any connection info/pinouts, please share it here. This will help with homebrew build and maybe eventually a store cable.
Here’s a real-life observation: I have the “store” cable for the Btech UV-25x2. The online diagram for the cable shows that the 90-degree end should be plugged into the Btech and the straight end into the Digirig Lite. However, that doesn’t work. What does work is if the straight end is plugged into the Btech. Has anyone else found this to be the case?
