Cable for Radioddity QT60
For QT60 I found this mic connector pinout:
Based on it, the audio cable for Digirig should look like this:
For Radioddity:
RJ-45 pin 8 (SP) → 3.5mm TRRS tip (RIG_AFOUT)
RJ-45 pin 7 (PTT) → 3.5mm TRRS ring 2 (RIG_PTT)
RJ-45 pin 6 (MIC) → 3.5mm TRRS ring 1 (RIG_AFIN)
RJ-45 pin 5 (GND) → 3.5mm TRRS sleeve (GND)
I came here looking for something about this radio and whether or not it was supported.
I saw there was an RJ45 cable for ICOM radios, but I’m not sure if the pinouts are the same.
Did you ever figure out a solution for your own QT60?
EDIT: this is nothing like an ICOM RJ45.
Here is some documentation from Radioddity about how to DIY an adapter cable for the QT60.
I don’t own this radio personally, I just posted the connections for a homebrew Digirig cable. At this time there is no pre-made cable for QT60 available in Digirig store. You’ll have to make one at home or order it from somebody who offers custom cables.
Just an update to this topic, I’m hoping there will be some consideration into making a cable available for these radios. It’s hard to make a good looking and rugged cable for an RJ45 radio so a nice molded cable would be great. Especially since the manufacturers have spent the time to update this model and the QT80 Pro to make a nice single-cable solution possible. Here is a web page that covers both models with info similar to the PDF KI4OTK posted. Please please please?? QT60 PRO & QT80 Data-mode Operation Guide – Radioddity
