Cable for TYT TH-9000
From the image this appears to be a view into the socket on the transceiver side.
Based on the above RJ-45 mic pinout Digirig audio cable will look like this:
RJ-45 Pin #1 (GND) → 3.5mm TRRS sleeve (GND)
RJ-45 Pin #2 (PTT) → 3.5mm TRRS ring2 (RIG_PTT)
RJ-45 Pin #3 (MIC) → 3.5mm TRRS ring1 (RIG_AFIN)
RJ-45 Pin #4 (MIC GND) → 3.5mm TRRS sleeve (GND)
3.5mm TS tip (EXT. SPK+) → 3.5mm TRRS tip (RIG_AFOUT)
3.5mm TS sleeve (EXT. SPK-) → NC
Make sure to leave sleeve on ext. speaker unconnected:
The front of the radio features a data connection. Likely serial so this can potentially be interfaced with Digirig’s serial port. From the looks of the compatible PC50 cable I would guess logic levels, but that needs to be confirmed.
Is this cable currently available? I could not find it on the site.
I compared pinouts and it looks like this one is a match:
Please post your results.
If I use the RPC Electronics, LLC: TYT TH-9000D MiniDIN Packet Adapter. What cable do I need to order for the Digirig Lite?
If I use the Masters Communications AC-25 Reapter adapter do you make a 1200Bd cable that would work with the Digirig Lite?
There is a MiniDin6 cable that should work with RPC Electronics adapter:
1200 baud variant in this kit: Yaesu FT-8xx Digirig Cables Set – digirig
and 9600 baud variant here: MiniDin6 9600-baud Audio/PTT cable – digirig
As far as AC-25 Reapter adapter goes, if the pinout lines up, then this cable may work: Alinco DR-135T 9600 baud audio cable for Digirig Mobile – digirig - it’s a 9600 baud pinout though.
