Thinking about this as a Winlink Gateway radio.
Which CAT config for Digirig?
Which cable(s) for the transceiver?
Thanks!
Looking at the pictures of the rear panel of this Alinco: Micro-USB connector described in manual as “Terminal for repeater connection”. No further info in the manual and no idea what that is supposed to be. No data connectors so interfacing will have to be done via mic connector:
This matches GX16 cable in store:
Since there is no audio output on the mic connector, select the variant of the cable with the headphones tail.
This can be used with any Digirig model. If using Digirig Mobile, any serial port configuration will do since we are not interfacing CAT control.
Awesome response. Thanks Denis!
