Are cabling diagrams available which show the cabling needed for each digirig model when used with a Yaseu FT-891?
The audio/PTT cable used with all Digirig models is the same and here is the schematic:
There are no other connections that should be made from Digirig Mobile or Digirig Lite. DR-891 has a second cable which is a USB connection:
