How is cabling setup for DigiRig DR 891 to Yaesu FT 818 ND ?
The best option for Yaesu FT-818ND is with Digirig Mobile in logic levels configuration - this will give you audio, PTT and serial CAT control.
When using with DR-891 you can only connect the audio side of the interface (black socket). This will give you the same functionality as Digirig Lite.
As far as cabling goes, you can use FT8xx kit for 1200 baud audio or a separate MiniDin6 cable for 9600 baud audio.
Thank you… ![]()
