I have the Digirig, with all the proper cables for G90. I hooked it up and struggles with FLrig, and WSJTx. and cannot figure out why this isn’t working. Is it my laptop, or is it the radio.
FLRIG doesn’t see the CAT, WSJTX doesnt, however, I did have it working on 12/4 for 2 hours, made contacts and felt really good. now I am wasted.
i hate it when something works then stops without telling me why it stopped.
so, did you rearrange your equipment in between the working to not working?
just trying to rule some things out.
if you unplug the digirig and plug it into another usb port on the computer, it will most likely assign a new comport entry/number along with a new usb audio device/number.
as far as flrig/wsjt-x, are you running flrig in the background and telling wsjt-x to connect to flrig?
(i think your screenshot shows a wsjt-x direct to radio connection error)
i would run wsjt-x by itself and start working through the links in the chain.
verify the comport number is correct
verify the rig control speed, 19200
seat/reseat the plugs on the digirig and g90
i run the g90 and the x5105 w/digirig and wsjt-x direct, no flrig, omnirig, etc
desktop pc as well as a maestro III laptop with good results.
Thanks for offering suggestions. I did have some success today, after I read you should not shut down the radio with the CAT cable connected- which I had done. The suggested fix I read was reflash the radio, but Sfter repeated tries I could not get the restart of the radio to queue up the zpropmt in TeraTerm, so I could resend the FW.
Then I tried one more time wit Digirig and Fldigi- Zit connected, and then using GlrigFlrig as the Radio in WDJT- I got CAT control.
So it is working with some finicky changes in Frequencies.
N4RJB
