Can someone please help me here?
I’ve got a KX2, hooked up to digirig using the digirig branded short cables. I am able to get CAT working, but not the PTT.
I may have found it. I think I had MIC Button setting on KX2 to OFF because for some reason when it was set to PTT once, it was causing the KX2 to TX as soon as the Mic cable was plugged in from the digirig.
Now that I set
Mic Btn: ptt
on the kx2, it appears to PTT correctly.
leaving post up incase it helps someone.
If anyone knows what causes the mic cable (fully seated) to cause the KX2 to TX on bootup sometimes while connected to raspberry pi, I’d still appreciate insight into that. As an aside, the cables are fully seated on all ends.
PTT line is controlled by RTS signal of the serial port. It is possible that something in your system is activating it at the bootup (there were reports of gpsd doing in).
