When buying the Digirig Mobile for use with a Yaesu FT-2800M what is the CAT Config option to select?
Brian,
Digirig’s serial port configuration doesn’t matter in case of FT-2800 because the radio is not going to use this capability of the interface. You can pick the default configuration if you don’t have other considerations. More on this here:
K0TX,
Thanks for the help.
73,
Brian
KG5GJT
