ClearRPT Allstar Repeater Controller with Yaesu FTM-6000r
I am looking for guidance on making the cable connection between the FTM-6000r mini din 10-pin connector and the Node-Ventures ClearRPT repeater controller. Pin to pin information is the goal. If I need to use something in between or just wire between pins. Search node-ventures dot com for the Clear RPT pin out. The Yaesu FTM-6000r pin out is fairly easy to find. Thanks to any and all who reply. KO4KVV
Here is FTM series pin out.
http://www.ve7ed.com/yaesu_ftm_to_tnc.html
Did you get your cable configured? Realize this is an old thread. I see they now sell ClearRPT connection cables to Yaesu already made. I am attempting to connect ClearRPT to a Yaesu DR-2x repeater.
bill kg5ie
