Hello dear om, I have a first generation ic706 which already works with an FT8 interface. To save weight and wires, I decided to install the Digirig box and ordered the cable for the ic706. Unfortunately, the CAT test doesn’t work on Wstjx, and I can’t find a solution. The connections are correct. Here are the settings tabs. Thanks for your help. Yours sincerely,
