Configuration Yaesu FT5DR - WoAD trough Digirig Cable
Hi, I can’t config both devices (Yaesu FT5D and WoAD on my cell phone) in order to use for Winlink operation with Digirig and Yaesu HT cable.
I just buy a correct cable SKU: YAESUHTMOBILE plus Digirig Mobile 1.6
• FT5D: In VOX operation (I try High and Low level)
• WoAD: USB Digirig with cable in Audio position. TNC type: Audio 1200 bps
Does anyone has tested this case?
Mauricio
CE3TDM
I had just given a similar configuration some thought and realized that it most likely won’t work. The problem is that WoAD needs to be used with a packet TNC . There is no software TNC for Android so far as I am aware at this time. You could use the Digirig to connect the radio to a Raspberry Pi running Direwolf and Pat Winlink, then VNC into it with your phone or a tablet. Otherwise, WoAD needs to have that radio connected to a hardware TNC like a Mobilinkd TNC3. I have successfully used a FT3D and a Mobilinkd with WoAD and APRSDroid. If you are bringing a PC laptop with you, no problem. The Digirig will work great with that using a software TNC like Direwolf or Soundmodem talking to Winlink.
To my knowledge WoAD implements AX.25 software TNC so it should work with Digirig without need for any additional hardware. Please see these posts for examples of working configuration:
https://forum.digirig.net/tag/software-woad
The author of the software is also participating in the forum so you can ask your questions if you run into any issues.
WoAD works in packet mode prefectly with Wouxum KG-UV6D plus the cable Btech APRS-V01 because I tested with my gateway CB3WLK. It seem the YAESUHTMOBILE don’t match with the contact of female jack of the FT5DR (many reviews about that). But it’s true, Mobilinkd TNC3 works fine, but is sold out.
That’s very interesting. It appears that I didn’t dig far enough in to the session settings in WoAD. I will experiment with it and see how well it works. There are a number of people in my club that could benefit from this. Thanks for pointing it out.
You can visit my video tutorial at Winlink para comunicaciones remotas y de emergencia - YouTube and download the ppt.
After playing with the settings a bit I was able to get WoAD to work on a Samsung S21 with an AnyTone 878. The settings I had to adjust were TX delay, default 200 change to 900, and FX.25, default 0 change to 16 transmission check bytes. After that it was sending and receiving messages just fine.
Thanks for the tip!
One more setting, also changed TX tail, default 20 change to 50. Don’t forget to enable PTT USB RTS. You will also need to put a check by the USB port below that setting. You will need to re-enable that setting each time you connect the Digirig.
Thanks for this! No issue with Digirig and laptop, but have been chasing my tail for weeks configuring it with WoAD on my S21 and VX6R. Made your changes on both my phone and samsung tablet and both work perfectly now.
We’re you able to figure out what was going on? I cannot seem to get my ft5dr or my ftm 300 to work with the Digirig mobile. If you got it to work, what were your settings on the radio and WOAD?
Anthony, what aspects of Digirig’s functionality doesn’t work? Audio to phone, PTT, audio from phone?
Hopefully I can explain it well, I am new to Winlink.
When I try to transmit through woad my ft5dr flickers. I turn on another radio and I can hear the packet trying to go though. The problem I am having is it will not connect to an rms station. Even when I am within a mile of it. All I get for the status is unconnected.
I have even tried my FTM 300 with WOAD and the same thing happens except it doesn’t flicker.
What Digirig model do you use?
Any way to try interface + radio from a PC to rule out that side of things? You’ll need winlink + sound modem to have the equivalent setup.
I have the digirig mobile. I can get it to work with winlink on a pc with vara FM and my FTM300 but not my ft5dr. I also cannot get it to work with the ftm300 or ft5dr and WOAD.
Let’s finish off with the PCs. What function doesn’t work with FTM-300 there? Audio? PTT?
The ftm 300 works with winlink on pc. The ft5dr will not no matter what I do. How donintell if it’s the audio or ptt as the problem?
Here’s a video on troubleshooting the audio:
My Digirig works fine with Samsung tablet using WoAD and FTM-400/500 and old 8900. I have the necessary cable from Digirig for my FT5D and will try that next.
vr
ww9z
