Connecting President Washington (CB) to Digirig for JS8Call
Hi everyone,
​I am looking for some guidance on connecting my President Washington (the new CB model) to a Digirig Mobile for use with JS8Call on the 11-meter band.
​The President Washington features a 6-pin microphone jack on the front and does not have a built-in USB soundcard. I am currently using a Sirio Boomerang antenna with a good SWR (1.1 - 1.2), so the RF side is sorted.
​A few specific questions:
  1. ​Cables: Which specific Digirig cable set should I use for the 6-pin President connector to ensure both audio (In/Out) and PTT work correctly?
  2. ​PTT Method: Should I configure JS8Call to use ‘RTS’ via the Digirig COM port, or is it better to rely on the radio’s built-in VOX settings?
  3. ​Audio: Does the audio output usually come from the 6-pin mic jack, or do I need to run a separate cable from the external speaker jack on the back of the radio to the Digirig?
​If anyone has this specific setup running, I would appreciate any tips on the settings!
​Thanks in advance!"
Erwin,
It appears that Washington model shares the same mic pinout as Lincoln. There is no off-the-shelve cable for either, but the pinout was discussed in this thread:
Please post the update if you decide to give it a go.
Hi everyone,
​I wanted to share my JS8Call setup for the President Washington. Unlike most setups that use the front microphone port, I am using the jacks on the back of the radio to keep the front clean.
​My Connection Method:
  • ​Audio Out: I use the 3.5mm External Speaker jack on the back of the Washington, connected to the Digirig’s “Audio” port for receiving signals.
  • ​PTT/Transmit: I use the 2.5mm VOX jack on the back of the radio.
  • ​Radio Settings: I have enabled the VOX function on the President Washington. This allows the Digirig to trigger the transmitter automatically as soon as it sends audio from the PC.
​Why this works for me:
This setup is great because I don’t need a special 6-pin microphone cable. Standard 3.5mm and 2.5mm audio cables (connected to the Digirig) do the job perfectly.
​Results:
It works flawlessly on JS8Call (USB mode). I’m getting great decodes from Greece and France using my Sirio Boomerang A antenna. My SWR is a stable 1.1 on Channel 1 and 1.2 on Channel 40.
​73,
[119DCG889]
Thanks a lot! i read this could’nt be done! ill give it a try! I have a Lincon 2 plus
