Connections on 706MKIIG
Hello, I’m needing some direction for hooking up my Digirig Mobile to my Icom 706MKIIG. I purchased the Digirig Mobile CI-V and the 706MKIIG cable kit directly from Digirig.
On the radio side, I know the round 13-pin connector goes into the back of the radio. Where does the other cable plug into? The Ext Spkr port?
And then on the ends that go into the Digirig, which cables go where? Do I follow the color coding (one is green, the other black) on the Digirig? One is labeled Serial (green), the other Audio (black).
I’m usually not this dense, but I’ve had a stroke and don’t always think clearly any longer. I would normally just try the different choices, but I don’t want to harm my Digirig or radio.
Thanks for any help you can provide me. 73.
-John K0JDR
The serial cable has green molding on the Digirig’s side. Other end of it goes into 3.5mm socket in the back of the radio labeled “remote”.
