Digirig 1.10 and Icom IC-2100 blown audio input
I have a brand new Digirig 1.10 that I was using just fine yesterday with an Icom IC-2100 with a Digirig cable. Today it can transmit but not receive. I have tested it with two other radios and both a Raspberry Pi running Direwolf and a Windows laptop running Vara FM. The Vara audio input shows no activity at all. I’m sure I have the right audio card selected.
Is it possible that the audio out from the IC-2100 damaged the Digirig?
If there is a failure it is unlikely caused by your radio. Digirigs are pretty hard to break and people really tried like connecting RS-232 serial lines into the audio socket (that’s up to 30V square wave).
If you are done with all basic troubleshooting and concluded that the input is dead then please PM me and I’ll handle the replacement.
Gentlemen, did you come up with a resolution on this issue. I’m having the same problem. Thanks
I received a replacement and that has been working fine.
-Pete
Dang, not sure what I’m doing wrong. The cable rings out according to the Digirig schematic.
I tried another dual band antenna and still no receive.
Did Denis replace the Digirig box and / or the IC-2100 cable? Which part fixed it??
Also, can you share your audio settings please – on the IC-2100 and within Alsamixer if you are using a raspberry pi.
KM6QAQ
I was using a Raspberry Pi. I don’t recall the ALSA mixer settings. I do recall the audio is fairly loud if I disconnect the cable. And the squelch is all the way off. A new DigiRig is what fixed it.
-Pete
Thank you for the response, Pete.
Jeremy
KM6QAQ
Pete, can I get your call sign?
Still having problems here. Have done extensive troubleshooting all day here. Need my RMS gateway up and running. Denis has requested that I send all of my digirig cables and the mobile box in for testing. Not sure what the turnaround time will be. Thanks
