What do I need to do with the solder pads to make it work with G90? I think the Baofeng config is same as TX500.
Thx!
Thx!
Baofeng (except for programming) doesn’t use the serial port so it can be used with any configuration. TX-500 configuration will also work with G90 as long as cables with TRRS connectors are used.
Great. So I dont need to do anything. Thanks!
