Digirig 891 connected to a USB A
Hello,
I’m planning to use a digirig 891 connected to an old PC with no USB C Ports, is it possible to use a USB A to USB C for connecting them without losing functionality?
Thanks in advance
Jose Luis Gomez, xe2jlg
Yes, you are not going to miss out on any capabilities or performance by using Digirig with USB-A port on your computer. Here are the cables for that in Digirig store or you can use any other data-capable cable with the same connectors.
Thank you so much !
Just worth adding a quick note that RFI can get to the cables pretty quickly so just any old cable shouldn’t be used unless you’re also adding a ferrite to that cable.
Thank you!
