Digirig and BTech UV-Pro
Has anyone gotten a Digirig to work successfully with the BTech UV-Pro? I’m using a Digirig Lite with a K1 cable and the BTech K1 adapter.
The bluetooth TNC works for packet, but I’m trying to get VaraFM working.
What is the issue that you experience with VaraFM?
Audio from radio to computer, PTT, audio from computer to radio?
PTT works. Audio in seems to work. I’m able to adjust the audio according to the Vara meter. I also get audio out during Auto Tune. (I’m able to hear it on another HT.) But I get No Signal with auto tune and connections fail. It definitely seems to be an audio issue.
I’m connecting to my own gateway so I know it’s not a problem with distance to the gateway or anything like that. My other HTs also work fine.
When I tune from the gateway I get good scatter plots from the HT, but still can’t get a report. When I tune from the HT I can hear the audio from a second radio, but Vara on the gateway decodes nothing.
Ok. The audio out is really hot. It’s over driving.
I was able to get it to work by turning the USB Speaker level all the way down and tune slider in Vara all the way to the left.
Even with that, only the lowest 2 levels out of 10 on the auto tune produce a usable signal.
I was able to get a completed session, but this won’t be reliable. I see other people saying they use this radio and it’s variants for Vara but I don’t see how.
