Digirig + Baofeng Black Cable- no PPT
Hello All:
Using a Pi Zero W and DigiRig to run a Baofeng UV-5R. Got the Baofeng cables (Black & Green) and using the black cable to go from DIgiRig to UV-5R. When I try to TX, no transmit from HT. When I use Dennis’ earlier trick to short the DigiRig Audio plug S to R1, still no TX on HT; no PTT. Cable shows connectivity between Audio TRRS and Black connector pins.
Tried a Kenwood TH-F6A as well (Kenwood K1 connector) but no TX there either. PTT signal levels? Any other thoughts?
Thanks - Jeff Marden/N1JCM
If cable connectivity checks out with the schematic in the product page, but you get no PTT from shorting the sleeve to the closest ring (R2 actually) then the issue is either connection to the radio or radio itself. Do you have any other accessory for this ration that support PTT? Like a speaker/mic.
Thanks for the follow-up. R2 = PTT on the audio connector - Corrected!
I have tested both the Baofeng and the Kenwood with SP/Mic’s and a Mobilink TNC3 in the past, but not recently, so I will do this again and report back.
Thx - Jeff Marden/N1JCM
Hello Denis:
Upon further investigation…
I plugged the Baofeng SP/Mic into both the UV-5R and the Kenwood TH-F6 and it worked as expected; radio keyed when the PTT button was pushed. Still no TX with the DigiRig and black cable.
I took the Baofeng mic apart and followed & measured the PTT circuit. Most notable is that the PTT signal from the radio is pulled to 3.3vdc via a 10K resistor in the radio ( as shown in the Baofeng UV-5R schematic). When in RX, the PTT signal measures 3.3vdc at the sleeve of the 3.5mm plug. When the PTT switch on the mic is pressed, this PTT signal is pulled to GND (and the radio transmits).
When I plug the DigiRig black cable into the Baofeng (or Kenwood TH-F6 and measure volts at the TRRS male plug, the PTT signal on R2 is not pulled to +3.3vdc; it appears open. My digital ohm meter shows continuity between TRRS Sleeve and 2.5mm sleeve/GND, and between TRRS R2 and 3.5mm sleeve/PTT. Again, when I short TRRS Sleeve and TRRS R2 together, no TX/PTT.
Any further thoughts?
Thanks,
Jeff Marden/N1JCM
Jeff,
Nice troubleshooting. So we know the cable has continuity, but there is no open PTT voltage on Digirig’s side of the cable. This would suggest a bad connection. Do you see any difference in the contacts size or molding between the K1 connector of the speaker/mic and that of Digirig?
You should also be able to check the connectivity between the sleeve on the Digirig’s connector and the radio’s ground without taking it apart (say at antenna).
Hi Denis:
No obvious differences between the SP/Mic connector and the DIgiRig Black cable radio connector.
I did check continuity between the radio GND and the black cable TRRS sleeve GND - none.
However when I stressed the black cable radio connector in its radio socket (pressed it in the socket) I did get continuity, and when I did this with the radio on I measured the 3.3vdc on the TRRS R2 PTT ring.
Looks like some mechanical issue between the DigiRig Black Baofeng cable radio connector and the radio socket @ GND.
Not sure what else to do, but thanks for the help!
Jeff Marden/N1JCM
How does the molding compare. There is a possibility that the molding prevent full insertion. That can be trimmed back if needed. If cable is somehow flaky, I can replace it.
Hello Denis - the molding on the cable looks good. I can see the two pins of the radio black cable all the way down to the gold base section, so no obvious problems with the connector interfacing with the radio. I have now tested on the Baofeng UV-5R, The Kenwood TH-F6A and the Icom W32 (which uses the same K1 connector) without success.
I can’t say if this is a flakey cable or not, but if I could get another black Baofeng interface cable to test that would be great. I would agree to return it if there is no change in operation.
Ok, I’m going to shoot you another black K1 cable when I’m back in office next Monday.
Much appreciated - I’ll update when I test this new cable.
Thanks,
Jeff Marden/N1JCM
I have a number of Baofeng HTs. It’s pretty well known that the quality of them is pretty lacking. On some radios, you really have to push the K1 connector in pretty hard. Enough to eventually cause damage. I put those ones in a pile and avoid using them for digital. I search until I find one that doesn’t do that. YMMV.
Yes, I lost quite a bit of time when I first started with the Baofeng HT by not pushing the Kenwood connector firmly into the socket.
I am having the same problem. Was this resolved? The digirig works perfect with my FTM-400, FT5D but not with the Baofeng. The Baofeng works fine with the TNC3. Is this just a cable manufacturing issue? 73, KN6GWQ
Martin,
Did you have a chance to confirm the issue with the cable by simulating PTT or checking the continuity of the connections?
After checking the continuity, I found the problem. I had to push the connector in REALLY hard to the Baofeng. Which was mentioned in a post on this thread. Now it works!!! Thank you for the quick response.
Thanks for reporting your success!
I thought I was pushing that connector in hard, until I pushed it in hard enough to make the connection!
Hi
maybe coming late to this> I have the Baofeng cable connected to an Anytone 878. I also have a a Baofeng I am listening on. When I go into sound modem I see the waterfall and when I use the Calibration I can hear the tones. When I start up winlink I dont seem to hear anything. If I have the serial port set to TCP then the PTT does work. If I have it set to com11 (My digirig shows up here) I see the Anytone transmitting but don’t here anything and it makes no connection with the winlink gateway.
Thoughts?
Andy,
This sounds like a general soundmodem/winlink configuration issue. I would recommend checking resources on this topic. I also found Digirig specific demo for this:
Please update the post with your findings.
Well I don’t have a great answer but I got it working to an extent. Rebooted my PC a couple of times. Mainly to do with device drivers. Turned squelch off. Tested with APRS channel and saw the messages coming in. Set winlink to use TCP/IP and I saw the outgoing messages but no reply.
Setup my Anytone 578 with the antenna on the car and it worked so suspect the HT is not reaching the winlink gateway. Have the Digirig 578 cable.
Getting the drivers working properly on the PC seems to have been the key.
Hi,
I also pressed the connector really hard (i.e.: I hear the HT cracking) and still don’t manage to make the PTT work in VARAFM. I also try VOX activated PTT. There’s no way I can manage to make the PTT work. Last post about this issue dates from 3 years ago. Nobody found a clear solution to this issue ?
