I already have the 6 to 10 pin adapter from Yaesu. I just need the cable to connect the DigiRig to it. I’m trying to get into Winlink. Any other suggestions from those that are currently using a DigiRig with an FTM-500 are greatly appreciated (settings, etc…). Thank you!
If you’re set on having the extra adapter, any of the Yaesu 6 pin din cords will work. If you don’t have a 6 pin Yaesu, then skip it and go for the 10 pin directly.
Here’s a 6 pin. Yaesu FT-8xx cords for Digirig Mobile – digirig
Here’s the 10 pin, which supports 1200 and 9600. Note there is another 10 pins, but it is 1200 only. You won’t use the CAT plug with the 500. Yaesu MiniDin10 9600-baud Data and Serial Cable for Digirig Mobile – digirig
Matt
Thanks Matt! I ordered it. Do you use Winlink with your Yaesu radios?
I do. (Sorry to resurrect such an old thread!)
Matt
AL0R
