I’ve tried everything. I’m running wsjt-x on Windows 11 Home. I don’t understand the error codes so I am at a loss. Any help would be greatly appreciated
Chris,
Do you have everything else working?
The CAT control is the last thing to set up after audio in, PTT and audio out.
You can set rig to “NONE” in the dropdown box while you are configuring other things.
As far as I know I have all the settings in wsjt set up. It’s just connect to the rig itself
Chris
Configuring all the settings at once could be a bigger challenge. When something doesn’t work recommend configuring and confirming one thing at-a-time.
Try disabling CAT section and starting from getting audio from radio to computer.
