I bought a Digirig to simplify cable management for FT8 when I am portable. However I am having problems getting it to work. My setup is KX3 & MacBook Air with WSJT-X. Direct connections to the laptop from the KX3 works fine, In trying to setup Digirig CAT control of KX3 I get the following error from WSJT-X:
Hamlib error: rig_flush: called for serial device
read_string_generic called, rxmax=4095 direct=1, expected_len=1
write_block(): TX 3 bytes, method=2
0000 49 44 3b ID;
read_string_generic called, rxmax=128 direct=1, expected_len=1
read_string_generic(): Timed out 1.003 seconds after 0 chars, direct=1
kenwood_transaction: read_string(expected=128, len=0)=‘’
kenwood_transaction: read_string retval < 0, retval = -5, retry_read=1, rs->rigport.retry=1
kenwood.c(624):kenwood_transaction returning2(-5) Communication timed out
2:kenwood.c(1098):kenwood_get_id returning(-5) Communication timed out
verify_kenwood_id: cannot get identification
2:rig.c(7478):async_data_handler_stop entered
2:rig.c(7508):async_data_handler_stop returning(0)
ser_close: restoring options
1:rig.c(1273):rig_open returning(-5) Communication timed out
while opening connection to rig
I am not running HAMLIB nor Kenwood. This happens no matter which of the 2 serial devices I choose (not the USB Audio). I have an RS232 Digirig which is recommended for KX3.
Any insights would be greatly appreciated.
73 de KN6OKN
Marty
