Hello All, I recently received my Digirig Lite with the Baofeng Cables and when I plug either the USB or USB-C side of the Lite into my laptop, the device is not recognized in device manager under PORTS (Com & LPT). In fact, the PORTS selection doesn’t even populate. When I use the same USB port to run Winlink with my Xiegu X6100 with a USB Data cable, the PORT is visible.
Having said all of that, configuring the laptop, Digi-Lite, BaoFeng BF-F8HP, and running Vara FM in Winlink, the Digirig will trigger the PTT and the radio with transmit but not connect to the Vara FM Gateway. How do I get the Digirig recognized by my laptop? Thank You for your Time!
73 W3SPR
