I purchased a Digirig-lite today at HAMFest. As soon as I plug my BTECH cable into the Digirig-lite, the red PTT light on the Digirig-lite comes on and does not turn off. When it is just plugged into the Android phone, the green light comes on, then when I plug in the BTECH cable, the PTT light activates. I have tried a couple of different cables and get the same result. There is no change when I plug in the radio, and I cannot trigger the PTT on the radio. What other actions should I take to resolve the problem?
Dave,
What is the BTECH model do you connect and what cable do you use?
It is my Guerrillas Guide stuff. BTECH-APRS-V01 cable and a Baofeng UV-5R radio. My Galaxy S10 crapped out and the new phone doesn’t have a headphone jack. Is it time to upgrade cables and radios lol?
Do you happen to have a Digirig cable for your Baofeng?
BTECH-APRS-V01 appears to be a passive interface from another vendor. It is not intended for use with Digirig.
Can you recommend you vorrect cable and vendor
Thank you.
The Digirig cable for Baofeng radios is this one:
Excellent. Got them Ordered.
Thank you
Plugged in the new cable and had instant success transmitting and receiving data.
Thank you for all your help.
Thanks for the update. Glad to hear you are all set!
