Digirig-lite & TX500MP
Hi, all!
Planning to use a Digirig lite to run digital modes on the TX500MP. Most likely on Windows/Rsp Pi. I Am going minimalist with this set up. CAT control will not be an issue because I will pre-set frecuencies on the radio or just use the CAT cable that comes with the unit at the cost of an extra USB port. Has anybody done this? Do I need to make any mods to the Digirig? It should work out of the box. If I am wrong pls let me know.
Cheers & 73 from Argentina with love!
CarlosMaria (LU3BMS)
It will work out of the box. Make sure you get Digirig Mobile in TX-500 configuration and select MP variant of the cable in TX-500 cable page.
Perfect! Exactly what I have. Will send update with settings and performance results for those interested.
