Digirig lite Ver 1.1
Greetings - All.
I purchased a Ver. 1.1 Digirig Lite. ( the PCB unit ) A while back.
I wanted to put it to use as a backup.
I have a Digirig with the Kenwood TM-71A set of cables. ( with Cat option ), as well.
Do all the interface cables that Digirig sells work with the 1.1 Ver. ( No CAT of cause )
What are the big differences between the Ver 1.1 and current that I should lookout for.
Thanks for any help.
Yes, all the cables are compatible. The configuration info from the current Digirig Lite tutorial applies to the unit you have - the differences between the revisions are of cosmetic nature.
Thanks for taken the time to reply - K0TX.
And thanks for the info.
Have a good one.
