Just received my first digirig as I wanted to use WoAD on my S24 Ultra and IC-2730B in my vehicle.
No matter what i do it doesn’t recognize the digirig as an audio device in WoAD settings.
Anyone have a solution to this?
That sounds frustrating. It is not clear to me what your setup is.
Have you tried an On-the-go usb cable and plugging the Digirig lite into that?
You know i didn’t think about trying that yet so I just went and plugged in my Hyper - HyperDrive Next 6 Port USB-C Hub into the S24 ultra. Then plugged digirig lite into hub and it then recognized it!
Opened WoAD and tried a packet with PTT to GPIO 3 checked and the red PTT triggers😀
On my IC-2730 i have squelch open and then turned volume slowly up and down. While doing that I notice the top colored bar on WoAD when session is active changes color and get wider going to green and if too much volume on transeiver then red. I assume adust volume to wide green and should be good?
Not close enough to a station to get packet out but this is progress ![]()
Thanks alot
Congratulations! Thanks for reporting your success. I just repeated experience others have shared on this forum.
Until you get more power or a better antenna, have you considered dropping down to APRS? It is less demanding, but there may be closer nodes and you can still check out your TX/RX that way.
