Digirig mobile and IPhone 17 pro max
Hello, I have a Digirig mobile, digirig usb-c to usb-c cable and ptt cable for Yaesu HT can I use this with my iPhone 17 pro max ?
Depending on your use case, most likely not. iOS restricts full access to USB serial devices, so it’s unlikely that the app you’re using will be able to control PTT on the Digirig Mobile. This is one of the issues the Digirig Lite addresses by allowing PTT to be triggered through one of the audio channels.
I’ve been attempting to use the digirig lite with limited success. Hopefully I’ll have some clear answers soon.
Just so that I can close the loop on this instead of leaving it open the DigiRig Mobile would require that your Yaesu HT has VOX on it in order to allow for it to work. Like @wh6az I would suggest that you look into the DigiRig Lite which removes the need for VOX function on your radio.
Wonderful thanks I will pick up the lite version and try that out.
KE9CYY Scott
