Digirig Mobile (RS232) and Yaesu FTM-150 programming
Hi. My Digirig Mobile is connected with the 9600 cable to my FTM-150. I can’t get software to use the RS232 for CAT control or programming. Nevertheless Yaesu says pins 1 to 6 on the 10 pin mini din cable is used for sound and PTT (like older models with 6 pin) and pins 7 to 10 are used for programming and CAT using a USB to 10 pin cable (with prolific driver). So if the reason is there why my cable does not seems to work ?
Hope someone can help or tells me howto.
73 Phil ON4VP
Coming back to this topic I now can confirm that using the green TRRS cable the Digirig Mobile will do RS232 programming. The clue is to proper follow the instructions in the ADMS-17 software and also in the FTM-150 menu. I succesfully transfered data to the software, altered some memories and settings and programmed everything back into the transceiver.
73 Phil ON4VP
Denis, if you reading this, on Windows the Digirig Mobile sound is good both ways but using a raspberry pi zero 2 w when I monitor the audio it is to weak (I have alsamixer set all levels to maximum) but I can’t connect, just a ptt but audio from Digirig to radio is bearly audible. I monitor on a HT in the shack. Any thoughts on this. Tnx, Phil ON4VP
