Digirig Mobile works fine at home but not when remote
I’ve been able to get Digirig-Mobile working fine with my Xiegu G90. I took my transceiver and laptop to a POTA activation, and the PC would not recognize the Digirig when I was in the park and away from Internet connectivity. The receiver’s output did not register in WSJT-X as it normally does.
I came back from the park and everything once again worked fine.
The only thing I did differently in the field is to plug the Digirig Mobile directly into a USB port on the PC; normally I plug it into a USB hub which is then connected to the PC.
Any suggestions would be appreciated! 73 - Richard KD3DGH
the hub “causes” the pc to assign a different “ID” to the digirig components than when directly plugged into the usb port.
it is the same behavior as setting everything up correctly on a usb port on the pc then plugging the digirig into a different usb port on the pc.
the usb audio device AND the serial/comport are assigned different “IDs”
so in the device manager, you would see something like:
usb audio device (2)
as well as another comport number, likely in the ‘teens’
so, long story short.
setup the pc and do not change the usb port or hub usage of the digirig mobile.
OR
look in the device manager, note the changes, and setup a wsjt-x configuration for the changed values.
then when opening wsjt-x, you can select which config to use.
best option is to setup the pc always using the same usb port/hub usage and you won’t have to deal with anything.
Thanks - problem solved!
I was able to repeat the behavior while plugging the Digirig directly into the USB port on the PC. Then plugged the Digirig into the hub, then the hub into the PC, and now it works fine.
Appreciate the guidance -
Richard KD3DGH
