You know that picture in the trouble shooting section? Well, I’m locked and loaded.
When I first got my DigiRig I used it to program 2 Baofeng Gt-3tp radios, no problem. Then my computer updated itself. The DigiRig shows up under :Other Devices" and will grey out or be in bold print when unplugged/plugged in. Under Com ports, it remains greyed out regardless so when I try to use Chirp I get "could not open port ‘com3’: FileNotFoundError(2, ‘The system cannot find the file specified.’,None, 2) I can plug in other programming cables and they will turn bold and work. I was going to re-download the universal driver but Express Zip says it’s either corrupt or an invalid file.
TIA, Greg
That is a high level of frustration! Which version of Windows are you using? Maybe your idea to reinstall the driver is the right approach.
I use Windows 11 to download the CP210 USB to UART driver from here:
CP210x USB to UART Bridge VCP Drivers - Silicon Labs (silabs.com)
The Windows 11 file manager lets me extract the zip file by right clicking and selecting Extract. (I do not use a 3rd Party application to unzip.) Then I follow the instructions in the ReleaseNotes.txt file for manual install. That is, I right click on:
“C:\Users\myname\Downloads\CP210x_Universal_Windows_Driver\silabser.inf”
and select Install.
THANK YOU! THANK YOU! THANK YOU!!
There is a high level of frustration, it’s the old “every time I learn the rules they change them” thing with computers and me.
But I am up and running so once I get my radios reprogrammed it will be time to try VARA FM. Fingers crossed.
Thanks again Constrained and 73
Thanks for reporting this great progress. Let us know how Vara FM goes!
